Dear expert,
Please can tell me function of that tool?
Solved by Sebastian_Eiche. Go to Solution.
Solved by bigcarl5000kg. Go to Solution.
Hi @S.MANICKAVASAGAM ,
a little bit searching in Internet help everybody: https://www.graitec.co.uk/blog/entry/advance-steel-managing-your-project-migration-to-a-new-version
This tool is for converting an old project to a newer version. The most users just open the old dwg, but this is not correct. And additional this could be used for converting for example the prototypes (your own) from one version to a newer one.
The steps are easy:
The result will be, that all the dwgs will be converted and the old files will be backuped in the backup folder.
This had to be done with prototypes, user connections and so on.
For a whole project we don't recommend to use a new version while the project is not ended. We always told our customers to use the version in which you start the project to avoid problems.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
