CONNECT ENDPLATE FROM PFC TO PLATE WELDED TO FLANGE ENDS OF A UB
cjharley1450
Message 1 of 9
cjharley1450
HI ALL
I am looking to create a end plate (150x75) to a plate welded to the flange of a 254x146 UB
now please don't giveoff I am using Revit 2018 steel connections "this is the same as advanced steel connection"
All advice will be greatly appreciated.
Clive
Replies (8)
Message 2 of 9
CHRIS_ASDL
In Advanced Steel you can use The Joint 'Two end Plates, Reference beam' I am not familiar with Revit but id Advance steel Joints are there then this should work.
Here's how it looks in Advanced Steel.
Kind Regards
Chris
Message 3 of 9
cjharley1450
Hi Chris
Well that is the reason to buy advanced steel, Revit 2018 has not got this connection type lol, Thanks for replying, is there any other way of doing it in advanced steel
Message 4 of 9
CHRIS_ASDL
Well that must be annoying. Especially after all the fuss about AS joints are now available in Revit.
I don't think there are any other joint macros that will do this. Can you do manual joints in Revit? Does it have to be this type of connection?
Kind Regards
Chris
Kind Regards
Chris
Message 5 of 9
cjharley1450
Tell me about it, lol
This is a pretty standard detail lol
Thanks for the help
Message 6 of 9
CHRIS_ASDL
No Problem. @múinteoir might be able to assist you as hes more familiar with Revit.
Kind Regards
Chris
Kind Regards
Chris
Message 7 of 9
cjharley1450
It's called a platform plate connection.. just answered incase some one else was as lost as me lol but thanks for the help buddy
Message 8 of 9
Here we go
A whole new set of questions while the 2d basics remain unfixed.
Message 9 of 9
cjharley1450
I agree, I am new to Revit over 20 years autocad I use about 90% still using lisp routines I made 18years ago & myself and a fried are in the process of making a 2D steel fabrication bit of software should be finished in another couple of months... a lot easier to use   & really how many companies are using BIM...
