How would you go about adding these stiffeners to align top and bottom of the shear plate?
What I am hoping to accomplish is have this be a connection I can use in multiple locations. I am not able to accomplish the following:
- Extend stiffener to column flange.
- Top stiffener aligned to top of shear plate.
- Bottom stiffener aligned to bottom of shear plate.
Currently I am using the "Shear Plate" connection macro. Here are my settings for the column stiffener:
Maybe it is not possible with this macro. If it is not possible with this macro, is there a different one I should use?
Does this need to be a custom connection? If so, any advice on creating that would be appreciated.
