Announcements
Column Grid Bubbles
advandes
Column Grid Bubbles
advandes
Advance Steel 2019
Is there any way to modify the O.O.T.B. column bubbles?
I would like to:
-Change the "oval" to a circle
-Rotate the text so it's horizontal
-Remove bubbles at one end
See attached. Thank you!
AAG
Advance Design
Replies (14)
Karsten_Bork
yes, it´s possible in Management Tools:
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Karsten Bork
Mensch und Maschine acadGraph GmbH
mick-CNF
To change oval to circle use management tools or double click the grid in the GA and change the balloon /frame to circle, uncheck the ticked boxes to turn off the circles.
If this information solves your problem please accept as a solution.
advandes
I have made the changes in the Management Tools, but I only have two options when editing the grid... None or Edging. See attachment. There must be another step I am missing??  Thanks for your help.
AAG
Advance Design
advandes
Also, I do not have the grips when I highlight the grid like you show in your screen capture.
.. and is there a way to rotate the bubbles?
Thanks for your help!
AAG
Advance Design
Karsten_Bork
like mick wrote, is not to change the bubbles in model, you can change this in the drawing with click in grid.
You can have two options, one is what I showed you before you in Management Tools. This is a absolute setting for all projects.
The second way is what mick wrote but only for this drawing.
Karsten Bork
advandes
Are you saying these settings can not be changed in the model and only on a drawing?  In my last screen capture, shouldn't I be seeing other options besides None and Edging in the Balloon(Frame): drop down?
AAG
Advance Design
Karsten_Bork
this option is only for grid in model, but it has nothing to do with how it is depicted on the drawing.
But it has nothing to do with how it is depicted on the drawing:
At the end you need the drawings for manufacturing and construction on site.
You can change this in drawing but only for this one drawing or glabaly in Managament Tools for all drawins
Karsten Bork
advandes
Can someone please tell me how to get to this dialog box? See attachment... I am using version 2019 and don't have this option.
AAG
Advance Design
mick-CNF
Double click the grid in a GA drawing.
Where did you image come from?
advandes
What's GA drawing? Because when I double click the grid in the "model" I don't get the same dialog box you do????
See attached video capture
AAG
Advance Design
advandes
oops. attachment here...
AAG
Advance Design
mick-CNF
General Arrangement or any elevation, end view or plan view that has been generated using a drawing style or process that has grid lines in it.
Not the model.
advandes
Ok, I understand now... I guess I wasn't clear in my initial question. I am viewing a model and have not generated any drawings yet. I was trying to make these changes in the model and not on a drawing. Sorry for the confusion... Ugh!
AAG
Advance Design
mick-CNF
No problem.
