Column and Beam connection - help
I consider using Advance steel so I try to build a simple thing and got  Frustrated.
It's Column and Beam connection as you can see on pics I added here (i modeled it with SketchUp) - a beam sitting (and welded) to a double plate at an angle  (connect together by bolts) and that double plate sitting and welded to a column.
How I make something simple like this easily  ?  is there an automatic way? can I duplicate the "way" to the next column-beam connection? There is a way that I can trim a column to a plate in an angle ? and how I align\put beam to a plate that is an angle easily?
Alon
mick-CNF
It can be done and you can copy the joint.
You have to play with the numbers a bit to get what you want.
If this information solves your problem please accept as a solution.
Mick Thanks ! the example you add is perfect I will try to understand that.
I sent you a private message.
Alon
