please advise if cleat plate can be automatically be generated as per attached screenshot.
Solved by Sebastian_Eiche. Go to Solution.
automatic? I think this is not possible, you could try the customer connection with the command:plate on beam and then reference to the other beam)
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
hello dear,
thanks to reply can you please tell me which command icon you referring to.
Custom connection commands
Sebastian Eiche
