For bracing macros look under the connections vault, the tube bracing types, there are several end types available, also there should be a central gusset plate type, but it may not achieve everything within the one macro, If the image shown is correct design concept, you may need to do one connection for the tubes and then another one to add bolts to the gusset and the angle section shown.
you can add bolts either by bolt groups tools or use the bolt on plate or section, under the custom connection.
John Bennett
