Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Circle folded plate
1 REPLY 1
votuananhvungtau
159 Views, 1 Reply
Circle folded plate
I have a circle folded plate saved as an 3D AutoCAD object (that exported from the Inventor).
I tried creating it by using Advance Steel (create folded plate function), but failed.
My final purpose is a flattened plate exported from the folded plate.
I have only been using Advance Steel for a few years and my English is not good.
I posted the AutoCAD file here, could some one please hepl me.
I really appreciate and thank you for your help.
1 REPLY 1
Hi @votuananhvungtau,
can you use this object as special part in Advance Steel (will be produced according to the model / drawing from Inventor)?
https://help.autodesk.com/view/ADSTPR/2022/ENU/?guid=GUID-E5CAFC93-D4E6-43BE-9C92-7A7292B489BB
 If not, you have several options, with a rather complicated path to the result. However, do not expect the same quality of the result, this cannot be achieved in Advance Steel.
One of the possibilities:
If you can export a 2D sketch for this object from Inventor incl. bend lines (polylines or other flat objects), import it, create a 2D polyline from the contour (if it isn't already) and then simply use it as a base for the polygon plate bigcarl5000kg_2-1708711366956.png:
https://help.autodesk.com/view/ADSTPR/2022/ENU/?guid=GUID-BD7A737D-8EAE-4E5B-B621-1E5DEDF85443
Example:
2D polyline
Polygon Plate
For the bends, you need the bend lines (red color) - help them divide the sheet into the necessary segments (here separated by color) bigcarl5000kg_5-1708712307793.png
https://help.autodesk.com/view/ADSTPR/2022/ENU/?guid=GUID-6AC68460-623C-4070-AA46-8980EF4948A7
Now create the bends (settings for angle and radius see inventor) in a logical sequence so that the bends can form bigcarl5000kg_7-1708712877274.png:
https://www.youtube.com/watch?v=VoBM74YX4uI
https://www.youtube.com/watch?v=r7BEKmyAglc&themeRefresh=1
1. bend
2. bend
3. bend
4. bend
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
