Change to custom prototype in custom drawing process
muleman1
Advisor Advisor
muleman1
I am sloooowly figuring out the many required levels of customizing drawing processes and styles, etc . I am trying to get our custom drawing process to use one of our custom prototypes. I think I found window where to change prototype but there are no choices...any suggestions?
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
arkli2009
The default folder for prototype is:
C:\ProgramData\Autodesk\Advance Steel 2017\Shared\Support\Prototypes
johnjmbennett
You should create a new file name selector,  but typically this would be part of a complete drawing process step.
to just change the prototype file in the selector dialog , just copy the actual name of the file from the location it is stored in ( normally the prototype folder inside AS), make sure you add the .dwg on the end.
example:   Mynewprototype.dwg
the system will go automatically to the default prototype location in side AS.
You our only need the file path if you wish it to use another route or location.
John Bennett
You should go first here as the previous users told you.
Then when you arrive there, You take One .dwg type ( a3,a4 , it depends on the type of drawing do you want to use ) and you modified it with the specifications that you prefer ( Company logos, notes , ETC ).
You can modified the lines and the numbers of the marks and all this type of things doing right click in the "Box" and clicking "Modified Block".
Then you save this new modified .dwg in THE SAME FOLDER (prototypes) with a different name , doing this you will be able to select the drawing that you want.
I hope you get the answered that you need.
Regards.
muleman1
@johnjmbennett thank you so much to take time to help us!! We were copying the correct prototype name , but not adding ".dwg" . It works now!
Thx to other posts too!!
