from what I recall, you can designate a camber beam drawing style as well as straight beam style for the single part presentation within the outputs.
typically I the steel member will have a natural curve within it, in the shop I have seen fabricators use this natural curve to aide the cambering process, as it is noted on the drawing as a pre process to the manufacture etc. also some steel providers also provide the pre cambering as an option when ordering the steel.
depending upon the camber height, then you may choose not to show this within the single part drawings that have holes drilled etc, as the measurement differences in the real world are impossible to achieve, but work with the natural deflection of the beam to achieve the camber.
link to an article over the use of the camber drawing style and its implementation.
https://graitec.com/uk/resources/technical-support/documentation/technical-faqs/faq-2297-how-is-a-dr...
please bear in mid though if the camber height is large and the span has several deflections implied, then you should consider modelling as a curved beam or poly beam if multiple deflections are induced in the design.
HTH
John Bennett
