Advance Steel Forum
Welcome to Autodeskā€™s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
center of gravity
6 REPLIES 6
desigan2015
7358 Views, 6 Replies
center of gravity
Dear All,
i would like to find the center of gravity of attached frame .i already tired using the command center of gravity and total weight calculation , but in the model  did not reference reference point. please advise
6 REPLIES 6
mick-CNF
in reply to: desigan2015
Should be there just a small white dot.
Window around the whole assembly and you should find it.
If this information solves your problem please accept as a solution.
mick-CNF
Sebastian_Eiche
in reply to: mick-CNF
the point is showing..but not seen. try to change the AutoCAD token "ptype" because this point is used for this. I change it to 8% and another point
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
mick-CNF
in reply to: Sebastian_Eiche
I don't really use centre of gravity very often but I didn't know you could change the type.Smiley Happy
Thanks a lot Mr.sebastian.. I have changed the point style and now i  can see the reference point.
