I know that advance steel can produce NC1 files so that is why i am posting here
I don't use Advance Steel I do However use AutoCAD 2007 but sometime its more of a hassle
I have a DXF Generator that I use With it too
We Get .NC1 files from our detailer
and I would like to know if I can manipulate a hole in to a slot I have searched and searched and can not find this information
first attachment is the original file(screenshot HSS31.png) and the second (screenshot HSS31test.png) is what I tried that did not change anything
I am trying to change the original 9/16 hole into a 13/16 x 1 slot
If this makes sense to anyone please help
Solved by AleckGiles. Go to Solution.
I have used this in the past with great success... https://www.atekautomation.com/steelsolutions/
Hi
Due the fact that a Hole, in Advance Steel, was generated by a Macro, after you generated the drawings and the NC1 file. Inside the Advance Steel environment you can not edit the dimensions of the hole.
In this case I suggest you Explode the drawing and follow the work to AutoCAD or other software to edit...
Good luck
- Marque "Aceitar como SoluĆ§Ć£o", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de UsuƔrios Autodesk Brasil
NC1 files are just glorified text files. So they are easy to edit manually if you know the code.
For a slotted hole try to match the above image.
1= X coordinate
2= Y coordinate
3= slot width (hole diameter)
4= always zero for a slotted hole
5= the letter l for Lima (not a figure 1) means a slotted hole
6= length of straight portion of hole
7= extra width beyond hole diameter
8=angle of the hole from X direction.
So I think yours should be:-
v20.00 50.00 20.63 0.00l 4.77 0.00 0.00
Aleck Giles, Structures Consultant, Graitec
Thank You
This is Exactly what I was Looking for
I thought Slots Were 0.001 so it never worked
thank you for clearing that up for me
