Hi
Could someone suggest the best way to get a camera view to a GA, at the moment I just select "Cameras to ANSI-D" then select the drawing to place them then OK, but a lot of the time the are placed on new GA sheets as it says that the views don't fit even when they should.
Now if I pick the cameras and use selected parts to 3d drawing I can select the drawing but just the style is not what I need, not showing hidden lines as its coming through as 3d view obviously, just an example of how they can be used just wondering if there is a work around for getting the cameras to GAs.
Apologies if I've confused this with my explanation.
