Cambered Beam Drawing Style
Does anyone know where I can find the Cambered Beam Drawing Style?
I need to create shop drawings on cambered beams.
crydee-AG1
Hi
It all depends which installation you have.
If you have the UK install then any beram with Camber properties where the Model Role is set to Cambered Beam will automaticaly use the Cambered Beam style.
In any installation, if there is a cambered beam style you should be able to find it under Parts on the Drawing Style palette. I don't think it is possbile to show the camber on an assembly drawing (at least not making sense).
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
I have just completed a project with cambered beams, Aleck is correct make sure the Model Role is set to cambered beams and the rest is OK. The camber does not show (see below)
The same goes for the assembly drawings the camber does not show.
Hope that helps.
Gary
