please check you you are using the tapered beam, not compound beam
Command line: _AstM4CrConByVb TaperedBeam
This command has opition to use plate in addition to having standard hot rolled flats.
know that in some fab shops in USA , the use plate plasmas cut from sheet, the process through assembly line to make welded beams sometimes tapered also. The tapered beam to allows you set to plate and the control the size you need for the plasma cut plate.
This is tool can be used for pre engineered buildings, very popular in USA.
John Bennett
