Announcements
BOM in drawing - part list numbering arrangement
Please help me sort the numbering in my part list. I would like that the Bolts will be located in the last rows of my list.  Beams, columns, and plates will be arrange like the following:
b1, b2,b3, b4, c1, c2, c3, c4, p1, p2, p3, p4.
Please see the image attached. You'll see that the arrangement of my parts list was scattered/jumbled.
Sebastian_Eiche
you had to add the Mainpart Pos Num, to the sortening list and then decide which content is the first to sort by, then the second and so on.
Have a look at the following pic, taken from a structural list:
Baugruppe means lot/phase, Hauptteilnummer: Mainpartnumber, Einzeilteilnummer: Singlepartnumber
So this list is sorted first to the lot/phase property, the next sortening is according to the mainpart and the last ist singlepartnumber.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
something's weird. I followed the arrangement correctly but nothing happen. 😞
I don't have the option: Main Part Number
I do have: Main Part name, Assembly Number, Part number.
I tried them all but no success.
jeffersone
@Sebastian_Eiche I made a BOM to be sorted by Commodity number (Item number in BOM) but it only reads the first digit to sort. Is this fixable? Number 2 should be second in the list.
Sebastian_Eiche
from my point of view: Itemnumber is defined as "text"  (string) in the databases, so if you enter a number in this field, it will be a text for Advance Steel.
And because of this a Sorting will be according to a text sorting and therefore the sorting is correct: 1 -->1(0)-->1(1)--> and so on.
Sebastian Eiche
