Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
BOM column widths
3 REPLIES 3
munrue
550 Views, 3 Replies
BOM column widths
I am attempting to produce some grating details. In the BOM I am running into a problem of the description over running the columns allowed and obscuring other columns. Also the length is shown twice? Attached is a sample photo of my problem.BOM.jpg
3 REPLIES 3
muleman1
in reply to: munrue
see if this thread helps
https://forums.autodesk.com/t5/advance-steel-forum/editing-template-for-lists-on-drawings/m-p/576236...
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
ChristianBlei
in reply to: munrue
Th external BOM allows the use of scripts to edit the data in the data field of a textfield.
Look at
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU...
You could use a script to limit the length of a string that is the data of a token. You would have to test how many letters will fit into your text box and then create a script to limit the string's length, like
= ILength.ToString.Substring(0,15). 0 is the start index of the substring, 15 its length....
This way you can avoid overlapping, but of course you may loose information that you need by cutting off a part of the string's end.
Christian Blei
CBT Christian Blei Tools
christianblei.de
youtube.com/channel/UCxjA_NbeScQy9C0Z1xjwXpw
alickomay
in reply to: munrue
iv been triying to remove the sizes after name  but cant figure out how
so i kept them and removed the  length filed
i edited the  grating name in maneger tools it was "redman fisher 41-100-25x5" change to to GR 41-100-25x5
and folled the   screencast from  muleman1 post above , to lengthen the profile field  an shorten the materal an weight
and removed unwonted fields such as area
aded name and date field for sum traceability (use group maneger  to add new feilds to group)
if its a single part drawing with nothing els at top u can make the list really wide
