Has anyone come across dimensions showing up with no %DimVal values in the dimension?
Dimension with missing dim values
This only occurs with a column assembly drawing.
The offending dimensions are the ones selected below:
If I toggle the dimension to absolute and then back it shows up.
![1734651131 (acad) Autodesk_Advance_Steel_2023_-_[222000_-_C7.dwg].gif 1734651131 (acad) Autodesk_Advance_Steel_2023_-_[222000_-_C7.dwg].gif](https://forums.autodesk.com/t5/image/serverpage/image-id/1447952iB3DFE5F4050DCB3B/image-size/medium?v=v2&px=400)
