Is it possible to bevel the curved edge of this pate?
Or would i need to recreate the plate in another way to achieve this.
Is there already a feature cut on that edge or did you create the plate shape first?
The plate was made from a polyline, so the command made that feature for the curve.
I had a similar situation on a recent project. I will check it once my script finishes running.
Hi @lachlanMPCXN,
a help from Forum see attachment ... it's tricky , but it works
DWG see attachment
@bigcarl5000kgThanks that worked perfectly
... and if you modify the command to *^C^C_AstM14CommAddFeatEdge, it will create bevel edge until ESC (no repeating of the command needed)
