Can someone suggest the best way to add US wood sizes to 2017.1. similar to existing timber sizes... maybe @múinteoir or @AleckGiles or @Kirk_bailey
Solved by muleman1. Go to Solution.
Solved by Sebastian_Eiche. Go to Solution.
Solved by Kirk_bailey. Go to Solution.
Really Easy way I did was
Go back into advance Steel and Reload defaults.
@Kirk_bailey THANKS! It was very easy with the good instruction!!!
@Kirk_bailey well I have the US wood framing sizes along with a couple LVL's too and have several in a small project. I need them to show in BOM, but can't see them in any choice from the BOM choices. I see them in numbering panel, but not in BOM? Any suggestion?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
@Sebastian_Eiche that did it !! Thanks !!
We are doing something very similar. We have created the timber sizes and LVL sizes in the library however we still can't seem to be able to get the Material Summary to list them.
Did you find a solution to allow these timber elements to be listed on BOM?
Thanks in Advance
see if this screencast helps. remember to always make copy of bom. prototype, etc before modifying,,,saves a lot of grief
Thanks for that Screencast. We finally understood the note on the previous thread, however your screencast makes it much easier to follow.
Cheers
@ecapati are you inputting your dims as millimeters? For some reason even when you using Imperial dims, you have to modify databases in metric....
ex: a 2 x 4 (1.5"x3.5") would be input as 38.1 x 88.9
