Solved by Emanuel.Nestor. Go to Solution.
Hi @arkli2009,
I suppose you are using the plotter Autodesk "DWG to PDF.pc3" and you get the filename like "(SP) 1008.dwg-ANSI D Advance Steel.pdf".
The PDF file name is automatically created from DWG file name - including the extension DWG - and "Model" or "layout_name" appended at the end.
There is no option to change this behavior when using "DWG to PDF.pc3" plotter.
What you could do is to rename the PDF files after creation.
You could use a "multi-rename tool" for that, to remove the ".DWG" part from all files at once.
I hope this will help you
Best regards
Emy
John Bennett
