So I would like the file names to be the same as the part numbers for single part drawings. Unfortunately, it seems that isn't possible because apparently the Drawing Name per the Filename Selector in the Drawing Process Manager doesn't know what to do when %Flat(01) isn't used. This is rather irritating because I would like my part sheet drawing number to be the same as the part. Instead, here's what happens:
So I still have to manually change all of my drawing numbers for all of the part sheets, except now it's even more messy. This should not be the case, and instead AS just wants to shove a variable in there.
If anyone knows of a workaround, I'm all ears. Otherwise, there is a big waste of time for the hundreds of part sheets per project just in naming files correctly.
