Autodesk Essentials - Imperial
Chapter 16.1 Autodesk Advance Steel Project guidelines:
On page 294 of this Training guide I dont understand item #21  ( see attached)
Kirk_bailey
Type in PURGE in the command line inside of a model and it'll open a dialog box which will have the objects you can and cannot purge.
Be careful when using this command as it can delete layers and some other objects you want to keep.
I'd recommend testing it out on a model you use for testing that isn't current and wont effect your current job.
In essence, the command is used to clean up the model of unused layers and bothersome blocks.
muleman1
@Kirk_bailey is this training guide you guys discussing in the drive link you sent?
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
Kirk_bailey
@muleman1 I don't believe I have this training guide, no.
muleman1
thx
