AS2020 Bug Embed Beam Seat Nelson Headed Studs Upside Down
I am currently working on 8 stair towers that require embed plates with studs for the channels to bear on in cmu block walls. For the life of me, I cannot get this macro to stay consistent and work correctly. I need a 1/2" x 6" x 8" plate with 2 1/2" x 4 1/8" Headed Nelson studs on them for the channels to sit on. If the plate layout is set to total, the studs come in upside down no matter what I do and I can get the correct size plate. If I change it to projection, the studs orientate correctly, but I cannot get the 6" width without the plate hanging off the back of the channel by 3" which puts it 3" outside of the wall on my embed plan. What is causing this to behave this way? Why is there not an option to offset it back to where it needs to be? Moving the UCS does not change anything. See the attached screenshots.
