Arch truss assembly
Message 1 of 10
Arch truss assembly
Hi everybody, I did an arch truss structure with tubullar section (as you can see on the picture 1) and I would like to connect the two sections in blue with a plate (picture 2). I tried to use "connection vault" but it doesn't works.. Someone can help me ? picture 1picture 1
picture 2picture 2
Replies (9)
Message 2 of 10
markhubrich
Try the Tube end to end and see how that works out for you.
...and fix the kiss export issues.
Message 3 of 10
Thank you, it works ! But I have another problem now... As you can see I managed to fix the two sections on the top,question 2.PNGbut for the blue one I've got this result:question 2b.PNG
The beam has lengthened and my plate isn't at the good location, why I've got this ?
Message 4 of 10
markhubrich
Try changing this setting to 40 and re-create that inner tube and see what happens. I have found unexplained phenomena happening with curved members on occasion.
Message 5 of 10
I changed this parameter and I've always got this problem for only 2 connections, all the others are good.
For the first one, it's the same issue than previously and for the second one I've got this:
The plate is shifted to the left.
When you told me to fix the kiss export issues, you mean this parameter ? KISS exports.PNG
Message 6 of 10
markhubrich
😛Fix the KISS export issues is my smart ass comment in my sig because the KISS export from AS is lacking. It's attached to all my posts. LOL I'll change it whenever ADSK gets around to polishing up the KISS function.
Is there a system line here where circled?
Message 7 of 10
markhubrich
@eric.schnitzler4  I think I got this figured out.
It appears to work without moving them around. I tried every way I could think of using the tube end to end but the results were very very messed up. Custom connection worked no matter what I tried to mess it up. BTW, I couldn't think of why (unless the engineer decided) the splice had to be at a panel point. It might be less work for all involved if the splice could be between panel points. The red parts could then be field welded easier than having the splice right at the intersection, ?.
See screencast.
There's always a workaround 😅 The file is in Imperial because my 8" pipe looked like drinking straw in your metric file lol. I'll attach screencast when it's done.
I hope this helps.
Message 8 of 10
@markhubrich
very good job 😉
Message 9 of 10
Thank you very much for your time and your help ! I'm a beginner on Advance steel and you just saved my life and my project ^^
Your work is perfect !
Message 10 of 10
Just a last question, how did you cut the lines at a panel point ?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
