API for Advance Steel
Dias_Antonio
Dias_Antonio
Hi
Is there a good resource material to get deep in API for Advance Steel?
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
Shtalberg
I've asked the same question...
Main resource is AS SDK. All other information is on the forum((
As I've understood there are no complete guide for AS API, especially .NET.
phliberato
Hello Antonio,
Christian Blein has already explained this topic in the following post:
https://forums.autodesk.com/t5/advance-steel-forum/best-way-to-work-with-autocad-and-advance-steel-n...
There are some broken links there, so I'm sending a new link for Advance Steel API guide:
https://help.autodesk.com/view/ADSTPR/2020/ENU/?guid=GUID-E1F6E27F-4942-4683-9368-76AD9F1E6016
Regards, Pedro Liberato
