Anchor Bolt Material Grade
steeldesgn
steeldesgn
How do you change the material grade of the anchor bolts in management tools. When I modify the material grade from 10.9 to ASTM F1554 the anchors in the table disappear. Does this mean that I have to recreate all the anchor info in the table using this new material grade?
ArjunGaba
@steeldesgn  Did you change material grade f1554 in management tool??
If you have made a grade in mT using new table properties will be be empty
You need to create using duplicate it and change the names as you want..
or you have to fill all the properties in table.
steeldesgn
As my post stated, in management tools under the anchors tab when you select the material grade F1554 it clears out the anchor chart. So my question was do i have to go back and renter all of the anchor information so that the material will show grade F1554?
ArjunGaba
@steeldesgn  as i tell above
