Advance Steel keeps crashing!
Message 1 of 17
 "AutoCAD Application has stopped working"
the only option is to click the Close program Icon!
Replies (16)
Message 2 of 17
múinteoir
Where does the crash happen? Can you start the software?
Múinteoir
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
Message 3 of 17
Advance Steel reopens, but as soon as you open anything it crashes! Not only the things that were open at the time of the first crash! So its impossible to use at this moment!
Message 4 of 17
múinteoir
Have you changed the drawing template that it opens? I would try reset AutoCAD to default then try open AS
Múinteoir
Message 5 of 17
I can open drawings using AutoCAD MEP 2019. Only Advance Steel 2019 refuses to open anything!
So I can't edit any of the steelwork at the moment!
Message 6 of 17
múinteoir
Reset to Default and try again
Múinteoir
Message 7 of 17
will do!
Message 8 of 17
How do I reset Advance Steel to Default? When I open Advance Steel, I don't see any options to reset! Do you mean I must get the Administrator to Reload Advance Steel?
Message 9 of 17
múinteoir
No, go to the start menu > All Programs > Advance Steel 2019 > Reset Settings to Default
Múinteoir
Message 10 of 17
dgorsman
@Anonymous - when requesting help, you'll likely get faster more applicable responses if you include critical information:
  • Software version, including any service packs, hotfixes, etc.
  • Operating system
  • Hardware specs (primarily RAM, graphics card, processor speed)
  • Additional considerations, such as using a laptop (independent or with a docking station), bootcamp on a Mac, etc.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 11 of 17
acbsdesign
Is MEP messing up with Advance Steel?
Same happened with me before using Autocad Mechanical.
I associated dwg file with Autocad dwg launcher to be opened with by default (or clean autocad) (Right click on the dwg file, open with, choose default program)
If this does not work repair SQL server from the control panel, and repair Advance Steel just in case.
This helped with AS crashing with AutoCad Mechanical.
Ilko Dimitrov
ACBS
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Message 12 of 17
I have the same issue with Advance Steel. I had almost 20 (yes, twenty!) crashes during last 3 hours. Resetting AS doesn't help, new nVidia driver doesn't help. Any advice?
Product version: 23.02015.0 Advance Steel 2019
Build on: P.162.0.0 AutoCAD 2019.1.2
Message 13 of 17
Sebastian_Eiche
the newest software driver is not the one which is the best.
Try these one: Autodesk
The crashes could have so much reasons, therefor we need more information about your system.
Is there an error message?
Do you have full reading and writing right to the Advance Steel folder?
does it appear since a few days or since you install the software?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 14 of 17
There is only message "AS has stopped working" without any code or explanation.
I have access to read/write to the AS folder.
I'm using AS for over a year. The issue started few days ago (one or two crashes per day). After reinstalling nVidia driver i'd say it went much worse.
I'll try driver from your link
Edit: the message after crash says "program AucoCAD Application has stoped working"
Message 15 of 17
The installation of recommended graphics drivers helps. Thank you.
I have one more question. After opening any model i see the following message:
GPU error: The Graphics Performance tuner has detected a problem and turned off high quality geometry.
Is it sth that i should worry about?
I'm using hp Zbook mobile workstation with nVidia Quadro M1000M 2gb vram
Best,
Message 16 of 17
Sebastian_Eiche
Hmm I think I the videocard is maybe not the best one. If it works...let it go.
Sebastian Eiche
Message 17 of 17
jasno
I had same problem with HP Zbook (intel and amd)
When i instaled new bios and graphic card drivers for Dell. everything work great
