ADVANCE STEEL'DE winkel gleich DIN EN 10056-1 DELETE
edogan2EKX9
edogan2EKX9
Hello
While Advance Steel draws angle iron, Winkel Gleich draws it according to DIN EN 10056-1. There are two different profiles here, one is the L profile without character space like L 70x7, and the other is the L 70x7 type.
L profile with character area such as 120x10.
when using these profiles with character space while loading these profiles into IFS
We get an error because of the space in between.
How can I delete or fix this?
bigcarl5000kg
I don't know, what is IFS. You probably mixed up two databases that someone gave you (your customer, ...)
Solution = change the database (tricky, dangerous if you don't know what you do)
If this should be a output data only (such a DWG, PDF, ...), use mapping in the table editor (MapinternToExtern in AstorCurrentAddIn)
A sample for another task:
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
