Advance steel become read only sometimes
vkumarB3V5H
vkumarB3V5H
Advance Steel 2022 occasionally becomes read-only and
requires reopening to resume work.
Dias_Antonio
It seems a problem in you file type, not Advance Steel. Read-Only appears when a file is blocked for edition in the properties window of these file type.
Unfortunatelly you did not post any image file to see what´s really happening. It hard to help you.
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
