Advance Steel 2022 problem with language version installation
mariusz_bossy
mariusz_bossy
Community Visitor
Community Visitor
Hello
I have a problem with installing the Polish (and any other) language version for Advance Steel.
I downloaded the file Advance_Steel_2022_en-PL_Language_Pack from Autodesk website.
Unfortunately I get a message every time (I attach screenshot). It is in Polish so below is the translation.
"Product not found.Before installing the product Advance Steel 2022 - Polish (polish) Language Pack you need to install one of the products.
Advance Steel Language Pack"
What is this about?
This same i get the same message when trying to polish autocad.
Dias_Antonio
Dear @mariusz_bossy
Any of an old installation are being identifying during the language pack installation. So rename all de folder files with a different name. For example (_old) and try again.
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
yowaup297332
Community Visitor
Community Visitor
If you are experiencing problems with language version installation in Advance Steel 2022, there are a few steps you can take to troubleshoot the issue:
  1. Verify System Requirements: Ensure that your computer meets the minimum system requirements for Advance Steel 2022, including hardware specifications, operating system compatibility, and any specific language requirements.
  2. Check Installation Files: Make sure that you have downloaded the correct language version of Advance Steel 2022 installation files. Ensure that the downloaded files are not corrupted or incomplete by verifying their integrity or re-downloading them if necessary.
  3. Run Installer as Administrator: Right-click on the installation file and select "Run as administrator" to ensure that you have sufficient permissions for the installation process.
  4. Disable Antivirus/Firewall: Temporarily disable your antivirus software or firewall before starting the installation. Sometimes, these security measures can interfere with the installation process and block certain files or components.
  5. Clean Installation: If you have previously attempted to install Advance Steel 2022 with a different language version, it's recommended to uninstall any existing installations completely before proceeding with the installation of the desired language version. Use the official uninstallation process provided by Autodesk.
  6. Temporary Language Change: If you are still encountering issues, you can try temporarily changing the language of your operating system to match the desired language version of Advance Steel 2022. This can be done through the language settings in your operating system's control panel or settings.
  7. Contact Support: If the problem persists, it's recommended to contact Autodesk support for further assistance. They can provide specific troubleshooting steps based on your situation and help resolve any installation issues related to language versions.
Remember to document any error messages or specific issues you encounter during the installation process. This information will be helpful when seeking support or assistance from Autodesk or other relevant resources.
bigcarl5000kg
is it possible to install other language packs (ENG, DEU, ...), before PL?
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
