@ The Product manager for Advance Steel and for Revit:
2020 will be a good year for some and may be a bad year for others.
2020 is when many of us will be renewing subscription and or making decision to stay or to leave.
A few have already left, frustrated with the Autodesk's management.
I hope most of us will stay with Advance.
You have the budget, and the personnel to make this happen.
This is a list that I came up with, summarized and cleaned as much as I could:
- Destination (new) dwg for section views or model views. When created from model, details numbering to be done automatically in the new drawing.
- POWER DIMENSIONS-Intelligent bolt pattern dimensioning, by clicking on the first hole rest to be dimensioned
- System line for beams to be an autocad object with possibility to move ends from Autocad properties
- Do not regenerate and move cut views during detail update.
- Still present- dimensions being messed up when detail is updated even with no changes being made in the model.
- Grid lines-visible on all erection plans
- Connection side on erection dwgs-Shear plate to be shown schematically as a short line, or if we have angle connection-clips to be shown schematically
- Coordinates in Advance Properties-option to manipulate end points coordinates from the properties
- Field Bolts Tokens or Lists in Main Parts Drawings-these are necessary when we have many beams on one drawing-a small table to show field bolts for each beam
- Round cuts dimensions to be improved
- Anchor bolts macro-PARTIALLY DONE IN 2019 VERSION-still cannot be used, please see referenced thread in the forum (not the idea station)
- Base pate macro improvements-default holes to be as follows:
1/2" Anchor Bolts: 9/16" holes in leveling plate and plate washer, 1 1/16" hole in base plate (9/16" default tolerance)
5/8" Anchor Bolts: 11/16" holes in leveling plate and plate washer, 1 3/16" hole in base plate (9/16" default tolerance)
3/4" Anchor Bolts: 13/16" holes in leveling plate and plate washer, 1 5/16" hole in base plate (9/16" default tolerance)
7/8" Anchor Bolts: 15/16" holes in leveling plate and plate washer, 1 9/16" hole in base plate (11/16" default tolerance)
1" Anchor Bolts: 1 1/16" holes in leveling plate and plate washer, 1 13/16" hole in base plate (13/16" default tolerance)
1 1/4" Anchor Bolts: 1 5/16" holes in leveling plate and plate washer, 2 1/16" hole in base plate (13/16" default tolerance)
1 1/2" Anchor Bolts: 1 9/16" holes in leveling plate and plate washer, 2 5/16" hole in base plate (13/16" default tolerance)
1 3/4" Anchor Bolts: 1 13/16" holes in leveling plate and plate washer, 2 3/4" hole in base plate (1" default tolerance)
2" and above Anchor Bolts: d+1/16" holes in leveling plate and plate washer, d+1 1/4" hole in base plate (1 1/4" default tolerance)
- Command 'Hide detailed parts', New Category in Advance Toolpalette-"Detailing"-hide detailed SP, MP
- Update and Batch plot selected external lists from document manager
- Railing Macro Improvements - Added items and Summarized-please see the idea station
- Automatic Section views to start from left end of beam
- Preliminary numbering order per shape, size and thickness-this is critical for infrastructure projects
- Anchor Points for Detail Views-since default views are moving during update-it will be helpful if we can constrain them in the drawing
- Prevent Detail Views to appear during update once deleted
- Allow manual depth manipulation for automatic cut views
- Weld to be a solid, edges to be beveled (cut) by these solids
- Choose Destination folder during batch plot of drawings from DM
- UCS placed at object to be ALWAYS with Y-axis up.
- Gusset plates – corner clips not to be combined with a contour dimension
- Running dimension symbol to appear only if there is a running dimension.
- Workable gauge included in beam detail title as a token
- Tube bracing dwg style to be improved-I can send the standard dimensions required
- Column sections to be placed on dwg in order
- Angle seat to be dimensioned to top of angle (column DWG STYLE), not to bottom edge
- Weld symbols to be per AWS / DOT’s -tried to be done in 2018-still not per AISC
- Delete revision clouds with revving down dwgs, rev down and edit revision for multiple sheets at once. If we need to rev. down all dwgs, we end up deleting revisions for 300-500 dwgs individually.
- Double clip connection-one clip shop bolted to main, bolts having different b/n/w combinations and web doubler on one side only.
- Breaks in extension lines in dimensions
- Gusset plate to columns and beam (base plate) macro-add shear plate between gusset and column (beam) option, currently plate is oriented at 90degrees to the gusset plate-THIS IS AN EVERYDAY CONNECTION, it is not done in Advance
- Horizontal Through Plates-Moment Plates to HSS column-these are an everyday moment connections-please see the idea station, I will forward details upon request
- Shear Plate to be detailed with punch mark (connection side) Near Side, currently it requires use of SP Plate UCS in order to make sure it is detailed correctly, for 50-60 different shear plates it takes time
- Finish of bolts to be included in connections macro
- Prevent moving of labels for holes during update (the leader snaps to weird intersection between contour of the hole and the symbol)
- Option for Manual labels for slotted holes-these have to be entered as diameter +length+frame
- Beam dwg style-cope depth dim closer to beam than the holes’ dim chain
- Project Folder Palette-working on 17-20 projects simultaneously, and having multiple windows open-this will save time
- Bolts-N or X to be taken automatically based on bolts orientation and plies connected
- Moment Connection Macro-Different values for cuts at top and bottom flanges
- Grid and Elevation List on MP drawings
- Select Multiple Labels for Identical Parts-select one, and select rest that are identical
- For composite beams-Shear studs quantities to be entered in beam's properties
- Weld symbols-need further improvement-(misaligned top and bottom text, fillet symbol too close to leader break, typ tale is too small and wrong angle between lines)
- Explicit quantity for Dummy ‘Assembly parts’ to be an option
- Locate Cut Symbols at Points of Cut View Creation
- Intelligent Connections to Cambered Plate Girders
- Do not dimension bevel in main views
- Different Values for X and Y clipping
- Dimension hole pattern in beam flanges to first hole only, combination between ordinate and absolute dimensions for cleaner look.
- Add bevel for stiffener plates in stiffener macro
- Moment Connections-Backing Bar dimensions and alignment-length to be 1” longer by default on each end, moving without exploding is not possible
- Sloped hole pattern dimensions to be improved for beam DS when miter cut is minimal
- Automatically renumber Cut Views when a Cut View is deleted-option in MT
- Oversized holes in Gable wall end connection from the joint macro for ONE ply only
- Submitted summarized and added items for Moment Connections W to W-03/2018 both in Herald test and on Idea station
- Multi-Labels for Beams-end reactions, shear+moment, camber, shear studs-similar to Revit
- Bevel Cut Command-Continuous (at HSS edge at moment connections)
- Grid Lines Spacing to be improved-constrain grid to grid by default, move grid by manipulation the constrain dimension
- Delete multiple section views at once
- Please prevent movement of section views names during update-
- Fix Detailing Dialogue once and for all-04/2018-SP, MP, E-dwgs on left, last always on top, enter “Grid Line A” during detail creation
- "Create Marking" to be included for through plate connection, not only for shear plates
- Through Plate Connection for one beam to column-
- Bridge detailing to be improved-o.k.-this may be over the budget-but there is a need for improvements-please see the idea station
- Attach grid lines to work planes
- Dimension requests-show dimensions schematically-on a sample SP or MP drawing-a simple part with dimension shown where it will placed if we add it to the dimensions requests
- Improve aesthetics in labels-these snap to weird locations, overlap, leader has to point at 10-15 degrees increments. Leaders to point at center of hole.
- Combine and align AS dimensions
- Labels to move with steel when steel is moved on erection drawings-if steel is moved 10’ to the left, labels stay even if they are re-arranged per compass using the new command
- AutoCad Block in Detail Title-we need to add attributes and lines to detail titles-attributes may be linked to a new drawing
- T.o.s. of Bearing plates in plan
- Call-out Detail-Bottom attribute to be centered
Ilko Dimitrov, ACBS
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
