Advance Steel 2018 problem model elements visibility
atelier.absinthe
Message 1 of 10
atelier.absinthe
HI...I've a problem with my model in AS.... the model, I see the connection but not the elements ... how can I fix it?
Here you can find the model http://a360.co/2skNNYM
Facchetti Davide - www.studiofacchetti.com
Davide Facchetti | Architect | Studio FACCHETTI | Bergamo - IT
Replies (9)
Message 2 of 10
CHRIS_ASDL
It looks like the elements (beams) have been deleted.
If you select a joint that was associated with that beam and then right click, do you get the option to select the Advance Joint Properties?
Kind Regards
Chris
Kind Regards
Chris
Message 3 of 10
atelier.absinthe
Hi Chris,
if i select a joint, i don't have a Advance Joint Properties but only Advance Properties....
I've never deleted the beams in my model.... i don't understand this!
Message 4 of 10
CHRIS_ASDL
If that is the case then I am certain that the elements no longer exist. If a beam is deleted then all the joints associated with this loose all there intelligence.
Do you have a .bak file you could recover?
Kind regards
Chris
Kind Regards
Chris
Message 5 of 10
atelier.absinthe
hi, in recover file .bak.... there is the same problem :'(
Is there a reason why this is happening?
Message 6 of 10
CHRIS_ASDL
They must of disappeared before the .bak file was created!
Have a look in the automatic save file location. You might get lucky and find an earlier file that you can recover. Search for SV$ files and rename it to .dwg
If not then you will have to remodel the beams again.
Kind Regards
Chris
Message 7 of 10
atelier.absinthe
Great shot!
Backup files found! Only 2-3 joints are missing but the big beams are present !!!
Thanks a lot Chris! When I go to italy I have a beer .... or a pasta dish! 🙂
Message 8 of 10
CHRIS_ASDL
Your welcome!.....A beer would be great 🙂
Kind Regards
Chris
Message 9 of 10
CHRIS_ASDL
Can you mark this as solved! Smiley Happy
Kind regards
Chris
Kind Regards
Chris
Message 10 of 10
atelier.absinthe
done! 😉
