Adding Beveled Washers for A325 5/8" Bolts on Stringers
So I have a quick question regarding beveled washers on diagonal stringers for our handrails. If you look at the image below, we want to add beveled washers as a standard when we draw up our handrails. Currently it shows normal washers but this is incorrect. Has anyone went through the process of adding this into the system? I would greatly appreciate any help on this one. We currently use A325 - Grade ASTM A325 with NAW Bolt assembly, Diameter is 5/8".
Thanks for your time with this matter
Stephen L
acbsdesign
Stephen L
Hi Stephen,
Attached please find my A325, it has set NaW Tapered
The washer will show as plate washer-no bevel, it is not possible to make it bevel in the model.
Please verify the length of the first 5/8"dia bolt you are using, just in case, it should be o.k.
L 5/8" bolt with beveled washer = Grip+5/16+7/8
Have a great day.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Thank you Ilko, I really appreciate this, I can't seem to find the attached file though. Is it possible to attach again?
Again thanks! Much appreciated.
acbsdesign
Hi Stephen,
It is MDF file, I will try again, hopefully, it will go through this time.
