Announcements
Add centre lines to drawings
When I detail PFC's and hollow sections with an offset, the drawing shows the system line instead of the centre line and therefore the dimensions are irrelevant for fabrication. (see my example attached, i.e. 6mm dimension)
If I right-click a view and select Advance Properties, I can go to the Axes tab and switch on the centre line (and consequently turn off the system line)
Is there a setting I can change so that my drawings run with the centre lines shown and not the system lines?
Thanks in advance.
AleckGiles
HI,
The detailing of Advance Steel is set up to use the SYSTEM line as the datum for all dimensioning. When selecting the position of the system line in the beam the user controls which point on the beam is most important and thus becomes the datum for the dimensions. Any tolerance errors in manufacture work away from this point to minimise any effect.
Ordinarily I would say you should never use the offsets to move the system line from one of the 9 key points predefined. Why put the system line 6mm from the heel if that is not an important or relevant point for you? Move the whole beam instead (ordinary move command) keeping the system line on a relevant point.
The only exception to this is channels or angles when you use the system points in the middle of the sides. These are actually in line with the centre of gravity and not the middle of the flange or web. So an offset to move it to the middle of the flange or web would be sensible. Most of the time though these items are dimensioned from the heel so that is where the system line goes.
Changing the system line for the centre line in your drawings will affect the automatic dimensions quite a lot. Obviously they cannot dimension the system line if it is not showing so you will have no datum for many dims. None of the dims are set up to work from centre lines so you will have to do a lot of manual work to dimension that.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
Hi Aleck
Thanks for your reply - very detailed and fully understood.
In the situation in my picture, you are saying that rather than offset the SHS tie beam to be flush with the face of the column, you would physically move the SHS?
This sacrifices the system lines "tying in together", but I presume this is better practice and I need to distance myself from wanting all system lines to "connect" and I should consider moving offset beams rather than applying offsets.
AleckGiles
Yes, it is a compromise. It is always good practice to have the system lines meeting and ending on other system lines when possible. That is particularly important if exporting the model to others such as for analysis. However, Advance Steel really doesn't care that much. In order to get good drawings the "lesser of two evils" is to move the whole beam rather than offset the system line even though that means the system lines may no longer touch each other.
Aleck.
LinkedIn
Understood, thanks for the clarification Aleck.
Julio_Soto
I know this post is 4 years old but in case anyone else stumbles across this same question you can turn off the system line and turn on the median line (center of the beam)
https://www.graitec.com/faq-item/faq-2448-how-is-the-median-line-displayed-in-a-det/
stuart_mcleod1
Thanks Julio,
It's another couple of years on, but great post.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
