Access label content using .net
iwafb
Advisor Advisor
iwafb
Hi All,
Does anyone know how to access/manipulate the drawing labels using .net? Understand this can't be done with AS API, but apparently it's possible using Autocad API instead...
Would like to be able to select a label and read the tokens it contains...
Sebastian_Eiche
not sure waht you want to do, but I think this will be tricky.
The labels are an AS object and as I know not readable (but I'm not sure 100%).
Maybe you describe a bit more, what is your target.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
bigcarl5000kg
The labels are proxy objects only, no properties via "LIST" command available, regardless of the object
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
iwafb
Thanks for your replies.
I had previously understood the same. That is, you can't dig into the label properties and manipulate the content. Apparently though, this is actually possible using ACAD api.
What I want to do is select a label and add content to it. For example quantity in assembly...
Ultimately, I want to select one label in a view. Automatically pick up all other labels in the same view that contain identical information. Delete all "identical" labels in that view. Modify the content of the original label.
bigcarl5000kg
Hi @iwafb,
I think you need to be an magician, to solve this challenge 😁 ...  maybe Mr. @ChristianBlei can help you
