Hi Guys
This isn't so much an Advance Steel question as a Lisp file question ...
I have been using a lisp file for putting a fillet on 3D polylines. The lisp file is 3DPOLYFILLET by Gilles Chanteau and it can be downloaded from the App Store. Until a couple of versions ago I had no problem using the lisp and it was the perfect solution.
Recently the lisp has stopped working on my computer - I say on mine because I have tested it on several of my clients computers and it works fine. The symptoms I get is that after I type 3DPOLYFILLET at the command line it looks like the lisp will run for a second and then I get no prompts and the command line reverts back to default.
The first thing I checked was that NOMUTT was set to zero. I also checked that SECURELOAD was set to 1 and, to be sure, I put the lisp file in a trusted loction as listed in the file options in AutoCAD. Still no 3DPOLYFILLET
I have unloded the Lisp, reloaded the List, moved the Lisp. Downloaded a new version, had Gilles to send me a new version and still it does not run!
Is there anything else that woul dstop a Lisp file from running?
Many thanks
Nial
AS CAD Services
Hi Nial,
there are a lot of posts covering similar problems in the AutoCAD Forum. Also you could possibly search the AutoCAD.Net Forum. A trivial problem mentioned there is that the location of the list file was not included in an AutoCAd support paths folder anymore....
Good luck!
Christian
