Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
2021 update cannot access databases
Masibanda-CE
Message 1 of 25
Masibanda-CE
What's going on here?! I just installed the latest version of AS2021 and get this error:
Also, there is no log file as mention in the dialog box. There's not even a folder called "USA".
I have no problem with v2020.
Replies (24)
Message 21 of 25
stephan.gumpert
For the original problem on this thread regarding path....
Assuming you have installed every to the default location.
Replace your ASSettings_Advance.xml (make a backup of course) with the attached file.
The location is here:
C:\Program Files\Autodesk\AutoCAD 2021\ADVS
Message 22 of 25
andres_urrutia
hi.
I have an spanish versión of Windows 10.
this xmls versión doesn't work
should we change the "program files" folder according to enviroment variable for the program files folder ?
have I explained right?
Message 23 of 25
Sebastian_Eiche
The folder should be the same. You could open the folder path, delete the XML file and then use the windows control- programs and features - select Advance Steel 2021 and click in change, after this you should have the possibility to use the 'repair' command. If this is running, the XML file should be recreated and all is working
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 24 of 25
vipul
@stephan.gumpert
Replacing ASSettings_Advance.xml with the one you shared WORKED
Thank you....
Message 25 of 25
BjornLorentzen4522
In my case this did work with reinstall.
thank you
Bjørn
