2 nuts and 2 washers in custom anchor
hamidreza6HMNC
hamidreza6HMNC
Hi all,
I want to make a special anchor assembly including 4 nuts and 4 washers like the following arrangement . However, when I press Apply, the 1st Nut and Washer go away!
1. How can I place 2N and 2W at the green marked place?
2. Which assembly shall I use in yellow section? I tried with a new custom assembly but the result was the same!
Thanks in advance for your attention.
Greetings,
Hamid
Kirk_bailey
create a new template & set it to something like 4N+3W because there are 4 nuts & 3 washers shown in the image you provided.
hamidreza6HMNC
Thanks a lot for your reply @Kirk_bailey ,
I have this done, but as soon as I press apply, the N and W at the 1st place go away and the combination fails!
Kirk_bailey
Oh! i think i see ur problem. Look @ the highlights on my image. you'll have select the diameter & grade first & be sure to check those boxes 1st on each bolt you want to customize & be sure to do it before you move on from the parameters tab & onto the set tab.
hamidreza6HMNC
Thanks for the suggestion, I followed it step by step as follow,
but unfortunately the result is the same! after clicking apply the 1st combination goes away!
iwafb
So it looks like theres a limitation to 3 nuts and three washers, even though the picture suggests 4nuts 3 washers should be ok?
I've tried different combinations, all work, but it deletes the last entries over 3 of each. Heads up, you want 4 nuts and 3 washers, but you're showing 4 of each in your settings, that's why both dissapear...
The next nut I add in any field dissapears...
hamidreza6HMNC
Hi and thans a lot for your explanation @iwafb
Sorry, I have to correct the question, I want to have 4 nuts and 4 washers in the combination.
So in this case if I change the combination to 4N+4W that might be solved. I will test it to see what will be the result.
Thanks again for your attention.
Best
Hamid
