Idea for version to be replaced with revision. Since version does not equal revision and since revision is a very important element (while version is not important), revision should be displayed in ACC, without needing to open the document to see what it is. It is very confusing to see V5 for a document in revision 01 for example. An idea how this could may be working for single uploading would be that each time you want to upload a higher revision to be asked if this is a version (for example you want to upload an updated version on the same revision) or is a new revision, in this case the system could alert if somebody is trying to upload the same revision. For uploading revision for mass uploading an idea would be to develop an importer where you could upload for example 100 docs together with a list that would have doc no., title & revision, etc
