Welcome to ACC Ideas! Please note not all ideas receive a response and top voted ideas will be considered for future development. Click HERE for more information on the feedback process. Thank you for your ideas!
Unique Project Number to Avoid Duplicates
To maintain data integrity, we want to avoid project number duplication. During project setup, can we enforce a requirement for a unique project number to prevent duplication across projects? Please advise.
1 Comment
mesut_pala
Observer
It’s disappointing that ACC still can’t support a basic requirement of effective document control. While ISO 19650 doesn’t explicitly forbid having multiple formats of the same content, it does require that each information container has a unique identifier agreed by the project team. In practice, most ISO 19650-aligned workflows treat different formats (e.g., native file and PDF) as representations of the same container, not entirely separate documents.
ACC, however, treats the file extension as part of the unique name, which means a document can be uploaded multiple times with the same identifier simply because it’s in a different format. As a result, the platform creates duplicates where most ISO 19650-compliant naming conventions would expect a single controlled container with multiple renditions.
This creates confusion, increases risk, and works against well-established information-management practice. It would be far more aligned with real project workflows if ACC could enforce uniqueness based on the document identifier—regardless of file extension—so that alternate formats are treated as related outputs, not separate documents.
