Welcome to ACC Ideas! Please note not all ideas receive a response and top voted ideas will be considered for future development. Click HERE for more information on the feedback process. Thank you for your ideas!
Submittal Spec Section Auto populate
Currentl,y you auto populate the spec section in the specification module. The specification module does not sync with the submittal. I would have to enter the one-by-one spec section in the submittal. Submittals and spec sections should sync with each other.
6 Comments
kate_parmenter
It would be great to be able to select the spec sections that require a submittal on our end, then to have that populate in the submittal register
rvmoore32712
You can use Autospecs to do this.
KaseeGlazeFCC
Community Visitor
PLEASE make this functionality. It is extremely cumbersome to individually create every spec section on every project that requires a submittal. As mentioned above the abilty to select from a list of spec sections for only the ones that require submittals would be even better. If you could add the ability to select the appropriate template,workflow for each one at the same time that would be great.
ksimonmcmillan
I completely agree with the need to sync specification sections between the Specification Module, AutoSpecs, and the Submittal Module. If spec sections (Title & Number) are already uploaded, they should auto-populate as selectable entries when creating submittals. This would eliminate the need to manually re-enter each section and streamline workflows.
For example, when building a submittal schedule, having a pre-populated spec list would save hours of setup time and reduce errors. It would also allow teams to quickly assign workflows and templates to only the relevant sections, improving coordination between GCs, reviewers, and submittal managers. AutoSpecs is helpful, but it doesn’t support manual workflows or populate the spec list in the Submittal Module. Connecting these modules would make the entire process more efficient and consistent across projects.
dhallN4MNX
It is crazy that this isn't a feature already.
Having to Manually Populate the Spec Section, when you already have the Data from Uploading the Specification.
Unless they are just trying to sell license to Autospec.
alon_gabay
Agree
In Procore its syncing and work together , when there is new publish to specification module its automate sync to submittal module and you can choose it when you create new submittal..
