When exporting a PDF Submittal Detail Report there is an option to embed attached files, but not referenced files. Manually inserting the referenced files to the exported report later is tedious and inefficient. The RFI tool allows referenced files to be embedded. Please can this functionality be provided in the Submittal tool as well?
Furthermore, it would also be helpful if there was an option to include markups on the embedded references because there are often important markups made on files referenced as part of RFIs and Submittals. Our current workaround is to export the file with markups from the Files tool and manually insert it in the exported PDF RFI/Submittal Detail Report. This is also tedious and inefficient. Please can there be an option to include markups?
