Welcome to ACC Ideas! View the ACC Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Selecting assets directly from the model
I created and imported assets(deutsch "Objekte") to track the progress at the construction site. Unfortunately, it is not possible to click on the asset directly in the model for example to change the status from delivered into installed. It is inconvenient when I am only able to click on the asset in the list but not in the model. Is there a possibility to arrange that?
Thank you in advance!
2 Comments
robert_smith
Hi @severin.wolff
This is supported today. Usually when clicking an object does not show the information, it has to do with the model structure and selection setting that is set in the viewer.
If you take a look at your "Selection Setting" within the Settings, and change the setting between "Last Object", "Leaf Object" or "First Object", one of the settings should allow the behavior you're anticipating.
Let me know if this works for you.
severin.wolff
Hello @robert_smith,
your solution did work with defining the selection setting as "Last object". The others did not work.
Thank you very much!
