Allow multiple different logins on DC on a single machine. I have two different Autodesk Accounts. I use the same computer for both. I want to be able to log out of one account and log into the other on Desktop Connector without needing to completely lose everything that I have set up on DC for the one that I'm logging out of. There should basically be multiple profiles within DC able to be set up. Each profile would have it's own workspace on the C:\ drive that could be set up. Then allow us to easily switch back and forth between the two without needing to close the app and open it back up. Then it should just change which folder structure it is accessing.
