Welcome to ACC Ideas! Please note not all ideas receive a response and top voted ideas will be considered for future development. Click HERE for more information on the feedback process. Thank you for your ideas!
Model Viewer Orientation (Project North vs True North)
Allow model viewer (viewcube) to be set to either project North or True North. Seeing as usually people set the project to project North to make it easier to work and add sections and control section boxes I think ACC Model viewer should allow the same.
When using the Section Cube, even thought the tool is extremely good, by allowing you to select several elements and creating a section abox around those, having that section box aligned to true north makes it very hard to control.
1 Comment
hermann.weissBYJPV
Measurements with true north are imprecise and very often do not allow an exact statement. Please use the option to switch between project north and true north in the ACC viewer.
