Welcome to ACC Ideas! View the ACC Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Model Coordination > Clashes
Idea:
Option to revert clash data to clashes list in case of miss selection of clash item on created issue by actually voiding/deleting issue item
Current behavior:
when Issue item is deleted, the clash data will not go back to the clashes list instead it will go with the deleted issue
3 Comments
thomas_seufert
It would be helpful if you could also view deleted collisions in a matrix. Perhaps in different colours (e.g. blue and magenta) to distinguish them from the actual collision list. This would make it possible to understand / check whether the deletion of the collision is correct.  A filter option by user, date and reason for deletion would also helpfully.
thomas_seufert
It would be helpful if you could also view deleted collisions in a matrix. Perhaps in different colours (e.g. blue and magenta) to distinguish them from the actual collision list. This would make it possible to understand / check whether the deletion of the collision is correct. A filter option by user, date and reason for deletion would also help.
hmonteiroXGRQW
I am looking for a document that shows how the re-clashing happens and even if I delete an issue will it come back if I haven't specifically flagged it as not an issue. Then I can delete the issue and it would have to come back as a clash. Not being able to organize clashes in any way let alone similar to Navisworks is really slowing down the process of coordinating.
