I’ve run into a consistent issue that’s causing real headaches. When we create and publish markups in ACC, they look fine in the web or mobile viewer — but they’re invisible through Desktop Connector or when the file is opened in any other PDF tool.
From what I understand, ACC stores markups as an overlay in its own viewer, not as an actual change to the PDF or DWG file in Docs.
That means the underlying file never gets updated, so Desktop Connector doesn’t see a new version to sync. If you open that same file in Bluebeam, PDF-XChange, or anything else, you’re looking at the unmarked original.
Here’s why that’s a problem:
The improvement we need:
This isn’t about forcing everyone to use ACC’s markup tool — it’s about making sure markups are universally visible and usable, no matter which viewer or workflow someone is in, particularly if some of the markup tools are sub-par. Right now, ACC is great for those inside the ecosystem, but it leaves a blind spot for everyone else.
