Our team has encountered a serious issue within Autodesk Construction Cloud regarding submittal revision control. Once a new revision is created, there is no functionality to revert or step back to a previous revision. This limitation presents a major risk and operational failure for our project. In cases where an incorrect file or action is submitted, there is currently no way to correct or undo that revision. This is absolutely detrimental to our document control process and is causing confusion, delays, and potential noncompliance with our QA/QC standards. At minimum, we need one of the following options implemented or confirmed as feasible: • The ability to revert to a prior revision or • An administrative override to remove or replace an incorrect revision without corrupting the revision history. Please escalate this concern to the appropriate technical and product management teams immediately. This is not a minor inconvenience — it’s a significant workflow gap that undermines
