Welcome to ACC Ideas! View the ACC Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Hide closed issues by default
Closed issues should be filtered-out by default in the issue list as they are usually don't require further activity.
11 Comments
I agree with this. Closed issues were hidden by default in BIM360, but in ACC they are always visible, forcing us to find workarounds to hide them manually every time files are interrogated.
serhan.genc
This simple point should be corrected immediately. Having to go to filter and set to prevent showing them is a way but foolish one.
Matthew_Franklin
Fully agree, closed issues should be hidden by default. Autodesk please resolve this in the next update.
KOP_Eltahan
Are there any new updates in this regard?
LucasFMartins_IPS
still waiting...
another thing that will be great is if the pins had a fixed size. So the far ones display smaller than the closest.
ruby.eisenbud
Status changed to: Accepted
Matthew_Franklin
Hi @ruby.eisenbud What does that mean?
rchristiansen
I'm begging someone at Autodesk to see and fix this.  I can't think of any logical reason to show closed items initially.  I drives me crazy to open Issues in Navisworks or Submittals on ACC Build and see closed items just taking up workspace that I then have to filter out.  On large projects, this is a nuisance.  If something is closed, I don't want to see it anymore!  If the need arises to go back and review something, it should be easy just to change the filters.  But the default should always be to hide closed items, period.  Please change this, ASAP!
@ruby.eisenbud  The requested feature has already been implemented. Can you change the status accordingly, please?
rchristiansen
@daniel.smejkal4275F  This does seem to be fixed on ACC, however Closed Issues still show up in the Navisworks Coordination Issues Add-In.  This app hasn't been updated since April 2025, so if this can be updated soon with recent changes, this should hopefully be resolved.
S-SUTTER
This change to auto filter out closed issues is causing confusion for our field teams.    Can Autodesk make this configurable so that on a project I can put in the default filters I want
